Charging car battery
Reg
Jan 12, 2008
435
My tow-car spends most of its life in the garage and I like to keep the battery charge regularly. At the moment I have to move the car out on to the drive to gain access to the battery. The cigarette lighter socket is only active when the ignition is on so I am looking to charge it through the towbar socket.
I have searched on the web and cannot decide which pins I should use. I am assuming that the 12v is direct from the car battery on the grey socket i.e. it doesn't go through a relay or ignition.
4,058
1,785
I have much the same access problem and leave my Land Rover on a smart charger via the 12S socket
Pin 4 is the positive and pin 3 is the negative.
4,058
1,785
http://homepage.ntlworld.com/mark1968/Towing%20&%20Wiring.htm
This link gives the wiring
Reg
Jan 12, 2008
435
I was trying to measure for 12v on the grey socket but couldn't get a 12v reading. Just changed the battery on the meter and now I get the 12v I was looking for on pins 3 and 4 like you said.
I was concerned that it might be going through a relay or something.
Many thanks
PS
Link is very helpful.
