Just collected our sleek new 2015 Coachman VIP 4060. Must say after a week on the drive getting to know the new van am NOT too impressed so far.
First off this van has a solar panel fitted to the roof to supply a trickle charge to the battery. The dealer and the manual stressed the need to disconnect if the battery is removed, However don't look around for an isolating switch because you will look in vain, so you have to dive into the bed box, find and remove the fuse situated under the solar panel control box instead! So with an abundance of LCD lights, screens dimmer switch's or whatever they have dressed this van up with the manufacturer apparently cannot manage a simple on off switch in a suitably accessible position.
Then there is the matter of the radio that cannot be turned off. All that is said in the manual is "switch on the ignition" which would be fine if this were a car but its not so how is the radio to be switched on/off? Answers on a postcard perhaps. My solution was to remove the front panel which at least removes the lights which show from the locker front. Maybe wire cutters would do the trick with a roll of insulation tape for when we want reconnect it!
But perhaps I was expecting too much for my 22+ grand.......
