Mat..........I knew that would get your attention,just wanted to pass on a couple of tips.
1/If you use a storm strap for your awning it can rub on the canvas so cut a mouse mat into three and put the pieces spongy side down between the strap and the canvas,the sponge will be softer on the canvas and the other side will take the rub.
2/Mouse mats make good lightweight place mats with the spongy side protecting the table and the other side is not affected by the heat.
3/Either get small ones or cut up a large one for non slip coasters.
4/Keep a couple in you locker to kneel on when pegging down the awning.
5/If you are going to business/IT exhibitions loeads of mats are given away as promotional material
6/Dont try any of the above with real mice!Or is that mouses?
