Cig Lighter Socket
Feb 3, 2008
31
Hi
How you connect a Cig lighter socket from the battery to run things like 12v hair dryer. I don't seem to have any such sockets round the caravan and just wondered the best way to approach this.
Dec 27, 2006
451
No need to fit a car type cigar lighter, if you visit your local caravan dealer you should be able to get an adaptor which has a 12volt caravan type plug on one end and a car type cigar lighter plug on the other, only costs a couple of pounds. Only thing to be aware of is there are several different caravan 12v plugs , so ensure that you get the correct one. Just plug it into the caravan 12 volt socket (not 230volt socket).
You can also get from Halfords etc a double/treble trailing cigar socket adapter very cheaply
You would just need to change the cigar plug for a suitable caravan plug
Sep 13, 2006
1,411
Personally I would not run a 12V hairdryer from the normal 12V sockets as the cable feed and connections to these is only thin gauge and could overheat or even catch fire, you will also run your battery down very quickly if you have not already blown the fuse.
If you look at the sockets in your car you will normally find that only the one with the cigar lighter will be fed by thick gauge cable and the socket itself is different.
Why not do it in the car with the engine running?
If you really have to do it I would wire a socket directly to the fuseboard using suitable size cable and fuse.
We have 3 way car type sockets wired direct to the fuseboard but the heaviest current devices we use are a beer cooler(and then only on hookup) and an LCD TV, we also plug in phone chargers, games, satellite and DVD players when required.
My wife and 2 daughters all have very long hair (close to waist length) and we let their hair dry naturally or by towel and hand method - even at home most of the time.
Mar 21, 2008
364
Hi Andy,
This was covered in the February issue of "Caravan" magazine (are we allowed to mention that publication on here?)
Let me know your email address and I'll send you a copy of the article.
The parts totalled about
