Citroen Picasso
I am changing my 406 for a Picasso and still can't decide whether to get a 2.0hdi or the new 1.6 hdi which appears to be more powerful.Any advice please?
i Currently own a 04 reg 1.6i petrol, nice car slightly underpowered, i know u r taking diesel however if you are thinking of towing with it citroen seem to realy restrict these cars, they give picasso's a lower towing limit than what would normaly be possible using 85% rule.
Dave,Do not want to be rude but I would have thought common sense would tell you that the 2.0hdi was the more powerful and in any case the 1.6hdi would almost be useless wi
th a caravan behind.Jim
There is a very good thread on the unofficial Picasso website. Here is the link http://www.citroenpicasso.org.uk/picasso/index.php?showtopic=3172&hl=1.6+diesel (suggest you hilight that address, right click to copy it and then paste it into the address bar of your browser).
Watch the weights. The 2.0 hdi has a max towing weight of 1300kg and can tow it comfortably all day long. The 1.6 is a much lighter engine and this is reflectedin the towing weight - not sure exactly what it is but around 1050kg. Would seem to make it a no contest!
922
Jim, Dave's right. The 1.6HDi 16V has 110 bhp and 177 ft.lb of torque whereas the 2.0HDi only 90 bhp and 151 ft.lb. On paper at least, the 1.6 doesn't sound a bad bet, especially as max. torque is achieved at a lower rpm, i.e. it has a flatter torque curve which is always beneficial, especially when towing.
Sounds like the Peugeot 307. The 110HDi used to have a 2.0L engine with a reasonable max tow. To meet lower emissions and therefore get more fleet sales, Peugeot changed to a 1.6HDi with the same power but the max tow weight has been dramatically reduced to 1000Kg. Citreon may have done something similar. So although the towing weights look like a typing mistake, they are correct.
