Coachman Festival 450 Access to Internal Wiring
Feb 4, 2025
15
I have a 2016 Coachman Festival 450. There appears to be a boxed in section that runs inside the above kitchen sink locker down to floor level. This is where it appears the wires are that come up from the battery box in the under seating locker.
I would like to thread a new cable down this boxed area but not sure how to gain access from that top locker.
Is it just a case of gently prising the joint apart? Can anyone give me any advice please?
Thanks.
Sam Vimes
2,790
2,267
12,935
Someone here may have the same van as you but even so including some pictures may help others answer your question.
Apr 23, 2024
645
516
1,135
Boxed in sections used to come in two parts with the two sections screwed together and the screw heads hidden with little circular self adhesive pads. .You may find the wires at the top exit on the other side of the vertical panel , again covered by a plastic 'box'.Looking at a similar 2026 Festival for sale on the web , is it the boxed section to the left of the sink? if so then look for those covered screw heads. Sometimes they glue a plastic section over the corner joint.
Feb 4, 2025
15
Thank you for your help. You are correct the fixing screws are indeed hidden behind the self adhesive pads. I was able to feed the new cable in and leave it looking as good as new.
Reactions: ProfJohnL
