coachman VIP 460/2 1998 help
Apr 6, 2025
9
Hi all,
I've just purchased a 1998 coachman VIP 460/2 but don't have a manual. I've contacted coachman but it's too old for their archives. I'm trying to get my head around the systems but am running into problems. (this is my first caravan)
the first set of issues is electrical I think:
this is with a new battery installed, and the source switch set to van, lights work, exterior water pump works
1)there's a fuse to the left of the stove on the bed/bench front above the switch for the immersion heater. I've replaced the 13A fuse but I'm not sure what it's for. I'm also not getting a light on it.
2)fridge doesn't seem to turn on - there's a switch in the cabinet to the right of it that is currently on
3) igniter on the range doesn't work (gas is flowing)
4)immersion pump might not be turning on. gas bottle is open, valve next to heater is open. not getting hot water.
5) water pump under stove runs but I'm not sure what it does - possibly the shower....
I'm brand new to this so forgive my ignorance!
thank you for any help!
-Tom
Apr 23, 2024
238
187
635
A few photos of the fridge, space heater and control panel and the fuse would help.
Its unusual for a van of that age and a coachman to have an onboard water tank with and "immersion pump", usually all water (hot and cold) is pressurised from the external water pump.
also The fridge is powered off 12V,not mains as is the igniter for the oven. Often coachman would fit a switched fused spur at an accessible position for the electric heaters on the space heater, So Activating the space heater (TRuma S3002) control , if the little green light doesn't come on there is no power to the CB and heaters.
Reactions: achadaphailcroft
Apr 23, 2024
238
187
635
Oh and the fridge doesn't work on 'battery' unless being towed by the car . the average 12V fridge heater element is about 125W which would flatten you leisure battery in about 2-5 hours.
Apr 6, 2025
9
Sorry meant immersion heater, not pump.
Cascade rapid 9 litre.
I will try the fridge on gas then.
Fridge is Electrolux rm4271 c40/110
when I bought the caravan I was told the gas space heater needed fixing so I haven’t tried that yet.
I’ll take some pics tomorrow
Sep 23, 2023
959
354
1,135
Not really onboard water tanks were fitted from 92 on larger Cosalt AbbeyTANK.JPG
Sep 23, 2023
959
354
1,135
Your water heater could be a Carver mk2 EG,the E being for mains electric (mine works off fused spare switch).The G is for gas.. Operating instructions for them and Truma(Carver) room.heaters and Electrolux manuals can be found on the web.
Jan 19, 2002
1,669
514
Hi Tom and welcome to the hobby and the forum.
You will hear of caravanning ‘off grid’ using the caravan without mains hook up. Caravan sites will generally have electric bollards on each pitch to enable you to plug in.
This will enable you to run the fridge on mains. the 12 v setting only allows the fridge to be cooled while travelling (assuming you towbar wiring including fridge feed).
The mains hookup also enables your battery charge to be maintained while on site - the 12v will run the water pump, most likely all the interior lights, possibly the loo flush (unless it’s a manual pump handle device). The water heater is likely a GE model allowing it to heat water either on gas or electric or for a quick heat up on both at once. Using on gas will require the 12v for operation.
With permission of a site owner you may be able to book an AWS technician to fully service the systems and help you out with information during your stay. The likely price would be in the region of 200 which would be well spent ensuring that no faults are present and your future safety.
2,380
Hi Tom Welcome to the forum enjoy your first caravan you should get all the help you will need they are great bunch on here.
Apr 6, 2025
9
I've managed to get the fridge lit and the igniter on the stove to work. (woohoo!)
still can't get the water heater to work. I did fid the main fuse board and all the fuses are good. I don't know what the trips control though.
here are the pics
Also anyone know where I can find a manual?
2nd picture is the fuse which sits in front of the water heater - not sure if its for it or not. I haven't managed to get the light to turn on on the switch yet - internal fuse tested fine
3rd pic is the immersion water heater
4th the trip panel. I've tested all the fuses on the left. there is a switch at the top that I'm not sure what is for. can't get it to light up either
5th and 6th are the heater which I was told doesn't work.
Sep 23, 2023
959
354
1,135
I've posted a manual for your fridge above,as I suspected it is a carver water heater and that is the fuse spare I mentioned,you can download water heater manual off the internet you may struggle for a manual for your 1800 carver room heater
Apr 23, 2024
238
187
635
Toad , thanks for info on inbuilt water tanks in some of the larger caravans. To the OP , one of your MCBs on the power centre is off . so that may be for the water heater , hence why the neon on the switched fuse spur is not lighting. If the MCB justs trips again then electric heater element may have failed your photo 5547 shows the electric heater element connection box at the back of the carver cascade water heater and you should be able to trace the white mains cable back to the fused switched spur above the controls for the water heater. The carver space heater ( Truma took carver over and subsumed their products into their own)so is basically the later Truma S3002 in all but name , one main difference is the exhaust on the Carver exits below the van and the later Truma it exits through the roof.
Apr 6, 2025
9
thank you!
thank you for this. Since I’m not on mains it will be running on gas. I’m getting a green light on the controller but not hearing a gas ignition and not getting any heat.
Apr 23, 2024
238
187
635
When you activate the water heater on gas the green LED should light , then if the gas ignition fails for whatever reason the red LED should come on indicating a fault , before that happens you should hear a 'ticking' noise as the ignitor tries to light the gas.There are various people on the net who can repair the now obsolete Carver Cascade. Sent one away for repair recently and was back within a week all sorted ( the client didn't know to drain the water system down in winter and the long rod holding the water tank onto the body snapped due to icing , also his bathroom sink mixer tap failed as well). On the space heater , there may be leds on the control panel , but not having worked on one I can't comment on what you should see. On the later Truma S3002 space heater on gas had no electronic controls/indicators
Apr 6, 2025
9
Thankyou! Any advice on tracking down what’s wrong? I don’t hear a ticking yet the green light stays on
3,934
...Truma took carver over and subsumed their products into their own)so is basically the later Truma S3002 in all but name , one main difference is the exhaust on the Carver exits below the van and the later Truma it exits through the roof.
Not quite true.
Carver were not taken over by Truma, Carver sold their leisure devision products to Truma.
And by 1996 the Carver SC1800 was an entirely different product with no common parts shared with any Truma products. Whilst the operating principles were similar there 1800 convector range of product could use an underfloor flue, but anything more powerful had to use an above floor exhaust and flue pipe or forced combustion.
Reactions: toad a caravan
Apr 23, 2024
238
187
635
Whilst on my gas course I heard it was a more like "I'll make you an offer you can't refuse " From Truma , promising to increase the sales of the Carver range( and this was from the instructor who knew the then owner of Carver) , then unceremoniously dropped the Carver range of products a few year later . If you have seen and worked on examples of the Carver 1800 next to the Truma S3002 on the bench ( testing and fault finding as part of the course) you would have seen the tremendous similarity in the aluminium heat exchanger casting , followed by subtle differences in the valve , burner and flue parts, it seems one must be a copy/development of the other.Whatever the truth, they are very similar yet different.
