Compass Camino 550 Drain Points
Hi does anyone know where the water drain points are on a Camino 550. I've drained the on-board tank via the blue drain point on the side. The only other I can find is the yellow switch at the front by the boiler. The hand book is lacking information, it says see ware system when talking about winter storage. Can't find a specific section on water system. I just feel that there must be more than the two I have described.
The yellow switch by the water heater is the drain point.
The lever should be vertical to drain, horizontal to shut.
Yes, lift up the yellow tap and then open all taps to help drain the water.
Always travel with my water heater empty, saves around 9kg at the front and helps with noseweight.
With usnit all depend on what we carry, if we have single gas bottle in the front, for a weekend, then have the water heater full if we have two bottles on a european tour the water heater empty , but all in the end on how the caravan tows. We change it as required.
Thanks guys, that's what I'd already done. There is another tap by the yellow drain point that looks as though it has a hot water sign on it. I was just concerned that the two drain points wouldn't drain the whole system down.
