i bought a compass corona 556 4 months ago . not used it yet and van been sat on drive since . have recently noticed that the toilet door is catching and basically have to force door open . does anyone have any idea y this is happening ?
Hi Garry , Had a similar problem on our 524 this turned out to be beacouse over the winter the van had been parked at somewhat of an angle therefor twisting the chasis not that his was too much of a problem as all went ok when we parked up again on flat ground, plus the cold will let it twist somewhat.
I hope this will help and yours will straighten up when you level up.
We used to have a 556 and my door used to do the same in winter. Usually ok once heating has been on. We had major problems with water leaking in the garage door. Had to make sure it was perfectly level all the time. It was a nightmare. Exchanged it in the end as we could not solve the problem
