Jaybee, from reading other comments with regards to the rear garage door leaking it sounds like Explorer will send out some type of spacers to pull the door in tighter. Only three days ago I contacted Explorer about my disappointment with our new and first caravan they said they wern't aware of any problems with regards to the garage door!!!!Our 556 is in for it's first service at the moment and also has a leaking rear garage door.
The dealer is waiting for some sort of plates to be sent by explorer which I think will pull the door in tighter.
It is truly amazing how the British don't seem able to make their caravans water tight.
We had a few issues with our van when new and felt we wanted our money back but it's just the perfect layout and spec for our needs.
Our dealer has rectified all the faults we had and hopefully the leaky rear door will be sorted soon.
I was told by our dealer that Explorer group decided to fit the rear door with two latches in order to pull it in more evenly to reduce water ingress. Ours is new and has two latches which in my oppion are very poor, unlike the main door when you want to close it you cant just push it and click it in, you have to turn the latches a 1/4 turn with the key. I think this is allowing for a lot of play on the door hence water coming in. Not only that, one night my wife was in the bottom bunk getting our son off to sleep when she saw rain coming in from the main door seal, top latch and the fixed lower window on the garage door. If anyone has had similar faults or a solution then I would be grateful to hear them.Back to the topic.....
Really depends how many kids you have, and their ages. We bought our fixed bunk 'van (Abbey Aventura 330), three years ago. Soon found that neither of our kids (now 15 and 10) wanted to go in the top bunk - lack of headroom and a pain to get in/out. We now use the dinette as one bed and the bottom bunk as the second. Top bunk is now a great storage area!
No problems with garage door. Note that this only has the one latch, whereas my mates Sprite Major 6 has two.
Does the water ingress problem coincide with the number of latches on the door????
