Complete Thetford removal
Aug 1, 2022
Has anyone tried to remove a C250CWE from an Elddis, so many faults to fix on it, I think easier to take it out and do in workshop.
2,189
11,935
I took my Dometic loo out. Easy once the secrets are learnt from YouTube. YouTube has much more for Thetfords. Give that a go.
199
19,235
jondogoescaravanning.com
Mine is a Thetford C200 which I removed completely to deal with some damp around the filler door. Hopefully the C250 may be similar. After removing the cassette, the toilet is held to the floor by four cross-headed screws. The front two are easy to remove but the rear two are at the bottom of two tube-shaped mouldings. A small piece of mirror helps locate the heads. Also remove the screws holding the filler door to the caravan wall. With screws removed, the complete toilet lifts off a steel hanger attached to the wall inside the caravan
