Condensation in awning
Sep 21, 2009
29
We have a Pyramid Corsican Awning and the roof drips with condensation.I have had many awnings over the years and this is the first time this has happened,we do keep the front top flap unzipped but still the same problem.
Have any of you good people ever had and cured this problem.
Bob
Jul 1, 2009
2,142
could be the roof coating its self it may be not breath able what you gain in water proof you loose in condensation.
4,332
Hello Robert,
Condensation is the natural effect of warm moist air coming into contact with colder surface.
The only real solution is to improve the ventilation through the awning and to minimise the activities that will put moisture into the air inside the awning.
I have said it before but it is often not realised that all flames produces condensation, so any open flames even BBQ's will add to the problem. In many caravans the fridge vents into the awning, so if you are using gas, then that will add to the condensation issue. If you can, use mains electric for the fridge as this will eliminate one virtually constant flame. Just as an aside, and LPG flame will produce almost as much water vapour when it is burnt as the weight of gas used.
Avoid leaving the caravan windows and door open into the awning when cooking, as the moist air will find its way into the space and condense as described. And don't forget that humans and pets also breath out a lot of moisture, so bear that in mind.
You have probably had condensation previously, but because the roof may have been canvas, the water droplets will wick into the fabric and be evaporated from the top side as the wind blows over the awning. I have noticed this with tents, The modern nylons are wonderfully waterproof, and keep the rain out, but equally the keep the condensation in. The older canvas type tent material would always dry quicker than the modern ones.
The biggest thing is to ventilate.
One solution is to minimise the sources of moisture, don't burn open flames (cabinet heaters or BBQ's) in the awning. keep the caravan door shut on cool evenings so the exhaust from the cooker dose not contribute. In some caravans the fridge flues into the awning, so
practical as it woel require a massive heatinput to the awnig to do it..
The only solutions are to make sure the surface is not too cold, or to make sure the moist air can ventilate properly.
Jan 31, 2010
12
Hi Bob, I thought it was just me. I had a Pyramid awning in the past and it was terrible for condensation. First thing in the morning having breakfast was a right pain. I've since bought a new caravan and new awning and never had the problem with the new awning, this is a Starcamp (cheap but no problems).
29
Hello John,
thanks for your reply. I agree with you as I stated I have been caravanning for a lomg time and had many awnings and this is the first time it has happened, we will probably replace it.
Bob
Sep 21, 2009
29
Hello Robert,
John L ,thank you for that,as I stated i have been caravanning for many years and this is the first awning that this has happened.
I am quite aware of the science of condensation.I am sure you are aware the varying temperatures day, night and times of year.
the fact is this should not happen,if it did everyone would be complaining of this problem.
I have one more thing to try and if that does not work we will change it.
Bob
Feb 16, 2009
1,144
John not on your own we have the same problem with the Harrington Awning, will try what l have read on the forum so far.
Wife like to have the window open at the side of the fixed bed at night may have to have that closed and give more ventilation to the Awning, one thing has soon has the suns up it soon dissipates.
NigelH
Aug 4, 2004
4,343
Please remember to wipe it as a dry as possible otherwise within a week you will have mould on the roof. Obviously thsi goes without saying if packing it away.
Aug 4, 2005
1,204
14
19,185
Hi Bob,
I'm not familiar with the Pyramid range of awnings so not sure of the type of material they are made from. What I can say though is that similar to you I have caravanned for many years using a "traditional" type of awning until two years ago when I bought a Sunncamp lightweight awning. I never experienced any condensation problems up until I used the lightweight version. I put it down to the material, as someone mentioned earlier - waterproof but not breathable.
Now back to a non lightweight material.
Hi Robert, we get exactly the same with our Corsican. October and November in Portugal we had very little rain but had the condensation every morning. We had to shake the awning to get rid of the moisture, otherwise it was breakfast in the rain.
We've had two Bradcot Classics which did not suffer this trouble.
Sep 21, 2009
29
Hi Bob,
Rob T, thanks for your reply.
The material is acrylic, i think now that is the problem it is rather heavy and as you say waterproof but not breathable.
Bob
Sep 21, 2009
29
Hello Clive thank you for that handy information as we have been looking at the Bradcot awinings.
Bob
May 2, 2005
227
I have a Dorema awning that suffered on the odd occasion from the indoor shower problem.
Now I pull back the awning skirt a couple of feet and leave the top foot or so of the centre zip open to allow a bit of air flow.
Never had a problem since I started doing this.
