Hi I have a lmc caravan which as no leisure battery I have since installed a leisure battery powered by solar panels in the van there is a Thetford n3000 fridge which needs a 12v supply to run on gas. You can operate the system if you purchase a battery pack but this only lasts for a few days which I believe powers the control panel would any person out there know how I can can connect my leisure battery to operate it to gas if this makes sense someone said you can do it through the 12s plug on the front of the caravan which would power up the controller on the fridge by the way the power pack is only 9 volts thank you Martin
