Has anyone connected two Aquarolls together to get the benefit from an 80 litre supply? There must be a way to set them up so one is connected to the whale pump and the other is feeding the first roll as it empties.
Just thought....loosen the side cap on the other Aquaroll slightly to allow air to replace the used water.How about buying 2 Aquaroll screw caps with fitted taps (Towsure or similar). Fit the new tapped caps to the top of the Aquarols and fill them at the site's tap as usual. When back at the 'van, lay both Auqarolls on their sides with the taps at the lowest point. Connect a length of suitable food quality hose to both taps and open them and Bobs your uncle. If you put your pump into either Auqaroll side opening (which is now uppermost) you will have double water capacity.
Hope this idea works.
