Keith I have read the link and take issue with the following
"The third battery type is the genuine "deep-cycle" battery, designed to operate electric vehicles such as fork-lift trucks, milk floats and golf carts. These have a different cell construction with much thicker, stronger plates than starter or leisure batteries, making them more resistant to physical damage caused by constant deep discharging. They are ideal for use in caravans, motorhomes and boats except for a couple of features: they are extremely heavy and bulky and they are very, very expensive. These disadvantages tend to outweigh the advantages of deep-cycle batteries and so, in most cases, the leisure battery is the most suitable for domestic use in vehicles"
A battery designed to operate electric motors has to be robust to with stand heavy current drain especially the initial high current at switch on this is why the plates are thicker. A leisure battery is designed to give much lower current drain (inrelation to starter motors and electric motors) but maintain a higher voltage.
When a large current is drawn from a battery the terminal voltage drops substancially which is not a great problem when used to drive an electric motor, however it is a problem when your using the battery to operate electronics such as a TV.
So a battery that best meets the demands found in a caravan is one that maintains its voltage so that the electronics in the water heater controller TV ect can operate longer over its discharge periode and the leisure battery is designed to do this.
Having explained this I now think that what may have happened to Dels battery may have a bearing on this. He uses his leisure battery to power his caravan mover and if the plate was faulty the extra power needed to drive the motors could have "buckeled" the loose plate and caused it to come in contact with another.
So this gives us a dilemer is a leisure battery suitable to be used with a caravan mover. In my opinion it is but it will reduce the life of a leisure battery especially if the battery is not imediately put on charge after it has been used to move the caravan.
