Due to health / age problems, I need to get a cordless drill, for use on the corner steadies. Any advice would be appreciated, and suggestions for type and model. Thanks
Ian, you've already got a long extension lead with you, the electric hook up lead. All you need to do is to make up a short adapter from an exterior socket to domestic.It is normally advisable for you to put down the steadies before moving around inside your van to get your electric cable unless you have it in the front locker. Secondly you will probably need a long extension lead to move around to the four corners of the van, so where do you obtain this and plug it in? Thirdly a battery drill is useful for othe jobs besides winding down the steadies!
Easier to use a cordless drill and avoid long extensions getting wrapped around the legs, but then every oen to their own.Ian, you've already got a long extension lead with you, the electric hook up lead. All you need to do is to make up a short adapter from an exterior socket to domestic.
