Bob, if you have let it run dry, then it is probably beyond saving.
If it was working last time you used it, and has stopped over the winter, it may just be stuck, try turning the impeller at the bottom, after removing the gauze filter.
You could try applying 12v directly to the pins of he plug, carefully!
If it is stopped fully, they are not repairable, but you do not have to replace the whole item, you can get just the pump and replace that, if you are handy with a few tools.
Personally I would replace as a full unit to get rid of the old water pipe, it is surprising how much algae and slime they have inside!!
Your local dealer will have them, or try looking on E-Bay, but they are not cheap anywhere
