Discharging the battery
Hi All, I understand that my Elecsol battery will work better if it is discharged every so often.
I'm looking for an easy way to safely disharge mine. I have set up a 12v lamp on the battery but it seems to be taking an age to get the voltage done. I assume this means that the battery is in good nick so I shouldnt grumble.
I've been searching for something that will put a reasonable load on the battery so that it wont take too long.
Hello Clive,
I would have thought a 12 volt telly might exhaust it fairly quickly? I had low readings from my Elecsolin this cold weather, and contacted Elecsol. They suggested two things;
1. The battery will recover with the warmer weather
Sorry, pressed the wrong button !
2. Discharge the battery a couple of times.
However, in the Elecsol book of words, it tells you not to over discharge the battery, and if it is discharged, to recharge immediately
I have never been advised to do this before with a wet battery, and I just wondered where you got the info?
Mar 10, 2006
3,266
46
clive
batteries have an internal resistance, it increases when cold,reduces when temperature increases.
This discharge advice is nothing new, but i think it's not worth the effort.
But i am not an expert.
When i worked we did have switch rooms full of batteries providing the HT switch gear supplies.The crew that perodically
maintained the batteries tested for specific gravity, i dont recall them ever doing a discharge routine.
It's easy to get confused with advice regarding NI-MH (rechargeable batteries) which do need to be fully discharged to negate the 'memory effect'.
I swear by my 'Optimate' for battery maintenance. It can be left on all the time and continually monitors and maintains the batery in top health.
I have also brought several old car betteries back to health using it.
Not ideal for a flat battery as the charging rate is necessarily very slow, but for maintenance they are ideal.
Apr 23, 2005
185
Clive, I wd strongly advise you NOT to do this. Many modern batteries cannot be saved if they are deeply discharged i/e flat. I had to replace my battery last season after I had left van in storage with the fridge still switched on. It did not matter how long I charged it for it never retained charge after that.
