If I fit a mover to my new van myself does this affect the warranty? After all I have to drill holes etc.
tia
tia
I assume you are refering to the warranty on your caravan, more so than teh warranty on the mover. TD is as far as I am aware correct, You should not be required to drill holes in the caravan chassis memebers. If you did that that will possibly limit ALKO's warranty, but most movers are designed to clamp to the chassis thus avoiding drilling holes in the metal work.Grahamh said:If I fit a mover to my new van myself does this affect the warranty? After all I have to drill holes etc.
tia
Graham Derby said:Yesterday i had a Powrwheel evolution fitted to my Lunar Delta. It took their fitter 3 hours to do and made a fantastic job. After looking at how it was done i would get someone to do it every time, it would have taken me days !!!!!!. I removed the old mover that was 10 years old. and this one is unbelievable compared to that one.
Hi StephenStephen1956 said:If it still had current flowing in the OFF position with the key in place it would not be much use as a isolator!
I think your dealer is telling porkies.
TD42 said:the only hole you should need to drill is in the back of the battery box for the cables to the motor & the isolation switch,the cables from the controll box are usually passed though a gas drop hole
Parksy said:Hi StephenStephen1956 said:If it still had current flowing in the OFF position with the key in place it would not be much use as a isolator!
Apologies for the hi-jack
I notice that in your signature box that there is a small diamond icon with a question mark visible.
Do you have to complete a word verification 'Captcha' box ( filling in hard to see letters / numbers)whenever you post on PCv forum?
If so please let me know, there have been problems with our anti spam software which has prevented normal bona fide forum members from posting properly. We are trying hard to resolve this and you should not have to complete any verification when using PCv forum.
If you are affected by this I can get it sorted out with Haymarket.
I'll forward your details first thing on Monday when the Haymarket office report back for duty Martin, you should be ok after that.Martin_E said:hey Parksy,
I have to fill the CAPTCHA thingy in every time when I post from my mobile, even if on my home networks :-((
A totaly unnessaccery reply designed to to create an argument well for the first time in my life I will bite. There is nowhere in the installation instructons telling you where to drill holes in the underside of the caravan.common sense tells you that the least holes the better so as a gas drop hole is normally 2/3 inches in diameter passing a pair of cables through will not create problems,or are you intermating that there may be a possibility of an explosion due to the proximity of electric & escaping gas???Damian-Moderator said:Quote " the cables from the controll box are usually passed though a gas drop hole"
Really????????????????
Please state where in the fitting instructions that it says to pass the motor cables through the gas drop holes,,,,,,,,,,,,,,,,,,,,no,dont bother, it does NOT state that anywhere!!!!!!!!!!!
The motor cables should be passed through their own holes, drilled by the fitter,
TD42 said:Thank you Prof, you have put the answer as I would have expected & accepted From a legal point you are probably correct ........
Sorry to wander off topic again but has your verification problem been resolved now Martin?Martin_E said:Cheers Steve
ps its still there today :-((
