Dometic alarm going off - FUSE REMOVAL AND Re-INSERTION
Nov 2, 2024
15
Our Dometic fridge alarm was going off and the warning triangle icon was illuminated. There are lots of threads regarding this but those causes and solutions did not work.
The only thing that worked was removing and immediately re-inserting the relevant fuse. I can’t remember seeing this suggested in any of the many posts and so have added this as a possible solution.
I have no idea why this problem occurred or why the solution worked. I realise there are several reasons why the alarm sounds but this is another possible remedy.
Reactions: Jcloughie
2,776
The old turn off and on again, always worth a shot. Thanks Clare and welcome to the forum.
2,350
Welcome to the forum. Glad you sorted it.
5,505
One of the main reasons for the symptoms the fridge showed is low 240v voltage i.e. at 5pm every one on site turns up their heating etc causing the voltage drop. Known issue.
