dometic fridge door catches
936
From you rlocal dealer or Leisure Spares
You will need the Model No RM**** and Production Number 0092****** from inside the fridge
40
If it's the type at the top of the door which slides left to right, and you are moderately handy, then these are a possible DIY repair with Araldite.
40
Forgot to say in previous post that an alternative is to use the 'spare' top hinge bracket (provided in case you want to hang the door the other way round. Carefully drill a suitable sized hold down into the top of the door and then push a suitable pin down thropugh the hinge hole into the hole. I have used a suitably sized split pin equipped with a short length of red ribbon for visibility and it works very well.
