dometic fridge problem
May 19, 2016
Hi good people .. I'm new here and was just wondering if anyone has any idea what is causing my fridge to do what is doing while on gas ... it burns ok in the normal way but after about 10 mins flames start to come out of the side of the burner tube, the part with the hole in the side to allow air in ..
i have tried to insert an photo i took just hope you can see it ..
3,595
Have you had the fridge serviced? If not I think that should be your first and immediate step Do not use it untill it has been serviced/repaired.
Unless you are gas competent , it is best to arrange for an eneginneer to resolve it.
