Don't let the doom and gloom about UK caravan build quality stop you from checking the obvious and cause you to jump to conclusions.
5,508
I’d still like to know if anyone has ever had their new caravan thoroughly checked by an AWS engineer?
9,484
Only brand new one I’ve had was a S5 Bailey fro Chipping Sudbury caravans and I didn’t have it checked, although we took our time on handover. But the van never gave any problems, and it was Chipping Sudbury who discovered the front and rear panel cracks in years 2 and 3 and they handled everything. Other than that in 9 years ownership it was our best van ever.
5,470
Not sure if it counts, but we had an AWS technician thoroughly check our previous 2016 caravan when it was about 10 months old due to numerous faults. We were shocked at the report and everything was pointed out to us.
Condition:
The caravan is in good condition throughout showing little wear and tear, with the caravan having had replacement front and rear panels fitted. This is evident from the uneven application of sealant to be seen at the edges of the awning rails along the edge of these panels, not something found on caravans from the factory.
Notable faults/Damage:
The front outer windows do not appear to have had the rubber seals refitted correctly causing the window catch to pinch the rubber and stop it from sealing completely. The upper window/skylight has been sealed back in using both white and black sealant with messy edges easily in view when sitting or standing inside the caravan. This window also has a small crack coming into view from behind some of the sealant at the bottom. The headlining appears to have been caught and damaged by something sharp. There are cracks coming up from the NS bottom corner of the front panel, one around 4-5 inches the other over a foot long.
Conclusion:
With the caravan not being a year old yet all work should be completed under warranty which I believe the front and rear panels have been. However I feel that the quality of the work in replacing these may not be up to manufacturer’s finish or standards; I would also be concerned with the window seals not meeting the window properly and the cracked window/skylight. The front panel cracking does not appear to be from an impact and looks to be more from the stresses applied it from the rest of the caravan, meaning this should be covered by warranty.
A slight curvature noticeable where the front panel meets the side panel may be inducing more stress than it was designed for.
The caravan was rejected a month later!
Reactions: Hutch and Dustydog
4,751
I dought that we shall ever buy a new caravan again, due to our age and Mrs H's back. But it does seem strange NOT, to have a damp report on a new caravan, it should be standard on a PDI check. What is on a PDI check sheet, I have had two new Coachman caravans and never had a "Tick" sheet.
1,819
I doubt a damp report would be of a lot of use on a new model unless it had been stood outside for some considerable time, as the damp on just built models may not have had time to show up.
Mar 30, 2012
41
18,535
As you all know and some of you have sadly experienced, a lot of people have found build quality of UK caravans on occasion, shall we say, lacking! We've had two brand new vans after our wonderful little Avondale (which did seem to have an issue on every trip out, but it was of a good age). Both have been good and pretty painless in terms of ownership, but this Buccaneer, our latest one has been outstanding. The quality of fit and finish, and the application of sealant in particular , has particularly impressed after I spent a day removing excess from various areas of our Bailey. We have had two small faults; after a torrential storm and a service the same week a small amount of moisture was found in the locker; new one due to be fitted imminently. And the sticky awning alarm relay leaving the awning light on permanently; pet hate of SMBO.
Any way we were away for the bank hols week and of course it was lovely for a couple of days before-with all windows open. Then the heavens opened and so did, apparently, the skylight of our van-a sudden waterfall appeared. Instant panic, I mopped up, rang the dealer and as soon as the rain stopped borrowed site ladders and got the gaffer tape at the ready. Only to find that some dope (yes me) hadn't shut the skylight properly leaving it on a sort of second step or vent setting. What a.................... sheepish and apologetic email to the dealer etc etc. Hopefully no damage done and no stains or marks anywhere! But the moral of the story; check the obvious and never jump to conclusions !!!!
Hi,
This is not to say that the UK manufacturers should not to be held to account for the problems most new owners seem to have, or the lack of dealer support to fix any problems. However it seems the US RV products don't seem to be any better or may be worse.
See here
View: https://www.youtube.com/watch?v=fHk5oThyHL8&t=1s
for an example.
However on reflection most UK built caravans chassis are built in the EU !!!!!!!!!!!!
9,484
Hi,
See here
for an example.
Strangely enough there’s a post today where a 18 year old caravan has a fractured front end frame similar to the one shown in the front page of your video. Sadly the owner is on holiday in France.
What on earth though your comment on built in the EU beats me. What that’s got to do with chassis failures isn’t really relevant, as anyway chassis failure on caravans thankfully seems to be rare.
Reactions: JezzerB
5,508
The chassis shown isn’t a chassis as I know it. It looks like a simple front end unit. Al-ko chassis are of course a series of components, like a Meccano put together by the caravan manufacturer for the particular model. Note the cross section does not look very rigid compared to an Al-ko. I’ve had B&B chassis and Peak years ago. I have no worries my Al-ko will go the same way as the video🤞🤞
Reactions: JezzerB
4,751
The chassis shown isn’t a chassis as I know it. It looks like a simple front end unit. Al-ko chassis are of course a series of components, like a Meccano put together by the caravan manufacturer for the particular model. Note the cross section does look very rigid compared to an Al-ko. I’ve had B&B chassis and Peak years ago. I have no worries my Al-ko will go the same way as the video🤞🤞
DD, i hope you mean that your chassis will not go the same way.
