Hi all.wondering if anyone could help us as we have no handbook, where would we find the drain taps (for winter storage) on a luner clubman 400/2, thanks
Hi Brian, don't know much about your van but the drain plug is likely to be located either below the point were the water pump connects on the outside of the van,large screw which can be undone using a coin etc. If its not there it might be in the floor locker next to the water heater in the form of a tap which empties though the floor.Good luck
I drain my Carver Cascade water heater as follows. Open all water taps then in the bottom left corner of your water heater (on the outside of the van) you need to undo the white plastic screw which allows the water to drain out. Don't lose the rubber washer from it!
Ahaaaaaaa thanks for reply, yes have noticed white plig next to filter etc, the other van we had ABI highway also had 2 drain taps at far end of van underneath, i just presumed all vans had these......... (but we all know what thought did) lol thanks
