Drippy tap
Nov 2, 2005
1,481
19,185
Hi Guys
We have a drippy tap. tap turns off fine but can't stop the drip
Can anyone help? Any ideas?
4,136
With some taps you can replace the sealing washer, but with ones like mine you cant so it needs a replacement tap.
Nov 2, 2005
1,481
19,185
thanks John, I think that too, hubby was hoping it would be just a little thing.
We never find those...
Sep 19, 2008
28
what type of tap is it?
I had a problem with the kitchen tap in our avondale at the beginning of the year. Ours is the mixer tap type, when I turned the pump on it leaked badly from under the lever you use to turn it on and off. I got a new cartridge off ebay for about 6 quid and all sorted. Its a pretty easy job to replace, took me about 15 minutes
Nov 2, 2005
1,481
19,185
Yes, its a mixer tap over kitchen sink. We have a swift 91 challenger if that helps.
Just looks a tap to me...it does drip from the tap and not from the knobs of which there is one either side...
Sep 19, 2008
28
If you want to attempt to repair this is how I did mine, On top of the lever of the tap there should be a small round cover about the size of a 5p, this should pop off to reveal a small hole down the middle of the lever, at the bottom of the hole is a small screw which holds the lever onto the tap, remove the screw and the lever lifts off, you should be able to see a big nut (mine was brass) which secures the cassette in the tap body this was the bit I replaced.
I found that you could get them for caravan taps, but this meant they were 2 or 3 time more expensive and are identical to ones for domestic use, just be carefull when buying one as there are several sizes.
I think this is like the one I got
http://cgi.ebay.co.uk/35mm-REPLEACEMENT-CERAMIC-TAP-VALVE-CARTRIDGE-DISK-/390223314129?cmd=ViewItem&pt=UK_HomeGarden_Kitchen_SinksTaps_GL&hash=item5adb1f3cd1
