Drooping oven door seal - Bailey senator spiniflo spinfo
Hi
Don't know if anyone has had this problem but when I use the oven (spinflo or spiniflo - not sure of spelling!) the oven door seal droops so much that we loose the effect of the seal completely and cooking takes forever and a day. The seal is ok when cold but as soon as it heats up down it goes!!
I've spoken to the dealer where we bought the van (Senator Carolina series 5) but they were no help at all.
Anyone have any suggestions?
Ta Giles
Thanks Vernon
I Have tried superglue but it didn't do the job. Maybe I was using a 'duff' tube!
Cheers
Giles
If there are any other suggestions out there I would be grateful. Thanks
if you mean the top piece they have changed it the new ones do not have a piece(stops it drooping if you can't beat it get rid of it) had ours changed on last warrenty service hope this helps my wife has not said it takes longer to cook
Hi Lee
Thanks for your advice. The offending droopy bit is the rubber seal fixed all around the opening of the oven that the door rests on when shut.
All advice accepted with thanks
Giles
