My only comment would be that it's much heavier than the advertised weight. We bought one at the NEC in October, and the stated weight is 29kg - but it actually weighs more than 34.5 kilograms - and I note the website is still advertising the 29kg. We ordered it on a Saturday and received it the following Tuesday, which was great service.
Quote from my original post:
On another forum I posted about the actual weight of our newly purchased motor-mover (E-go) compared to the advertised, and salesman promoted weight. Initially we though it was a lot heavier, but after removing most of the packaging it is still more than 5.5kg heavier than the quoted weight of 29kg. If weight is an important consideration (which it was for us), then can I suggest that before you purchase you actually check the true weight of the mover. I said in my original posting that I'm not sure how many people would actually check - as most people get a fitter to fit the unit rather than do it themselves. I don't suppose it's easier to get a true figure - as, like us, the salesman is likely to tell you the advertised weight rather than the actual weight.
When everything is unboxed and out of the substantial packaging the weights are as follows: Motors plus one third of the cross bar 12.1 kg each = 24.2 kg Middle section of cross bar, plus clamps, bolts, brackets, control panel and trunking 9.3 kg Cross activation bar 1.0 kg so I suppose at 34.5 kilograms a good bit less than we first thought, but still significantly over the stated weight. I think they should be honest enough to admit this - after all they base a lot of their sales patter on the e-go being the lightest on the market for the weight of caravan it will move. End of quote
We haven't fitted it yet - the weather has been much too wet to start lying down under the van!
