Edds Caravan Floor
Oct 3, 2005
276
Hi
Thanks all who replyed to my post re work on my floor.I have now got the carasfe floor adhesive from an outlet in Norwich Norfolk,the cost was £29 for the stuff with the small pump.
Now the dowls are 30cm long by 8cm,With only 8cm holes how on earth can you get the old stuff from the floor,and do you push the dowls into the holes as soon as you have put in the adhesive,Many thanks again,
Mar 29, 2005
405
michael
23 Oct 2005 05:18 PM 01:33 PM hi,delamination...frightening no if you set out your stall and take your time.this is not a two hour job as stated,when you have finished you will know why they charge so much at the caravan repair shop.i have just done ours a few months ago.i will go through the steps best i can.ours had gone in two places,next to the door entrance and next to the sink four feet away.you will find that delamination is where the floor is used most.ie next to the sink and the door entrance.first decide how much delamination you have,ie.2 feet (old school) or 6 feet,this information is required when you go to order your epoxi resin mix.one mix will cover about 3 feet by 3 feet.got mine from barrons
