Elddis 415 vogue hot tap in bathrrom problem
Sep 18, 2005
56
18,585
forgive me if this has been asked and covered elsewhere, but we have just bought this caravan, and treid out the water system after renewing the piping to tap coz of damage, the cold taps in the bathroom and kitchen work great as does the hot tap in kitchen, but when we try the hot tap in bathroom in runs for about 10sec then goes off can any one help please.
Andrew..are the taps microswitch operated or is it a pressure system,look under the sink and if it has wires going to the taps then it's microswitch.
Mike.
Sep 18, 2005
56
18,585
Mike.
Hi Mike thanx for your quick response it has 2 wires going to each tap in bathroom so yes i would say it has switches
Andrew
Andrew, it would appear that the micro switch for the bathroom hot tap is faulty. You can prove this by opening the cold tap slightly to operate its micro switch, which will start the pump and then open the hot tap to get the water through ( there is a seperate microswitch for each tap but of course only one pump - so opening any tap will set the pump running).
The reason you get hot water for a short while when opening the bathroom hot tap is because of the pressure in the water heater.
Andrew, is it possible that you disturbed the connections to the nicro switch whilst replacing the hoses?
Beat me to it Ray i think it is a microswitch fault ,get yourself a service kit rather than a complete tap.
Mike.
Mike, yes sorry for butting in, I didn't realise it was a 'live' discussion or I would have waited to see what you said. Best regards. Ray
Sep 18, 2005
56
18,585
excuse my ignorance we are new to this, so if we open the cold tap slightly then try the hot tap we should get water thru hot tap and would this prove to be a micro switch problem.
Live discussion but open to everyone ,the more the merrier. You seem to know ya stuff do you work for a dealership by any chance?
Mike.
Mike, No I am just a caravanner of a number of years with a bit of technical knowledge. I caravanned with a DA section of the C&CC and there was a wealth of knowledge spread amongst the members. I belong to the age group who used to strip car engines down at the weekend for fun. I guess our generation knew how electro/mechanical things worked, whereas nowdays they know how to load a computer program. Incidentally that was the time when 'Practical' in the title of a magazine meant what it said. I cut my teeth on Practical Motorist and could strip car brakes down at 18, I think that more articles of 'how to find faults on the 12S caravan wiring system type opf thing would be useful in PC. (In this over protected day and age there would have to be a disclaimer '12v electric can be dangerous etc).
It never ceases to amaze me though that caravans are considered complicated. I don't know much about the method of building the body but there is nothing else that requires a specialist knowledge. There are loads of users of this forum who know the workings of the cascade water heater in fine detail, or at least enough to daignose a malfunction.
Aug 23, 2004
35
Electrical cleaning spray will quite often get the microswitches operating again - most of the problems I have come across with these switches are down to dirty contacts - Worth trying before buying any new parts anyway.
Haydn.
Sep 18, 2005
56
18,585
Hi Just wanted to say thanx for the advice micro switch has been replaced and we now have running hot water in bathroom.
Thanx again
Thanx again
as Haydn says next time try a squirt of wd40 as they some times stick or if it gets too regular change the system to a pressure type it dont cost that much compaired to replaceing micro switches
