elddis avante 524L (2003) & Suncamp ultima 390
Feb 17, 2009
6
I have an elddis avante 524 L(2003) model and am thinking of buying a suncamp ultima 390 or the smaller version(260?) Can anyone offer advice as to whether the 390 will fit? and how I go about checking this?
May 12, 2011
364
We have the 390 which is of course 3.9 metres wide. So you just need to check that there is a position possible with the two rear legs 3.9 m apart that
a) does not obstruct the windows or doors
b) does not extend into the area at the front where the awning rail starts to drop.
Does that make sense, probably not. Its hard to explain without the van in front of you.
The 390 just about fits from a few inchs aft of the lounge window, right to the rear of our 7.29 m Swift Charisma 550. Forward of the lounge window the awning rail is too sloped to use. So you do need quite a long van for the 390. Maybe the blunter nosed Baileys can fit it in front of the window but I think it unlikely.
Oct 6, 2008
179
I have a 2004 524 firestorm and a 390.
If you position the rear of the awning so that it sits between the side marker lamp and the toilet access flaps,just before it starts to bend, it will fit .
This way it only covers the front side window by about 6 to 8"
I have not found any other better way than this.
Mat
