I have an Elddis Storm (1998) and the blow air heating has stopped working. It still blows air but doesn't heat it anymore. Has anyone got any advice / experience with fixing it ?
My heater uses a battery to ignight the gas which you have to replace so make sure its not that. You should hear it clicking when you turn and push it onto full. Hope it helps
Hi Dave, I presume the fire is a carver with a fanmaster blown air system? if so it may be that the fanmaster has tripped, to re set, looking from the front of the fire on the rear left hand side about the 8 0-clock position there a reset button,it's only a finger of plastic hard to find if you've not done it before,just give it a try, may solve your problem.
