A few electrical problems have arisen with my S3 Cartagena.
Things started to go wrong with the mover (PowrTouch). Sometimes the rear motors would start to work and then stop. If I turn the isolator switch off and on they will start to work. The fault isn’t dependent on load or time – sometimes they will work fine for a minute or two on a hill and then trying to move a few feet on a flat surface they will stop.
Next, we noticed a smell in the awning of hot plastic – not burning, just hot. It seemed to be coming from the area of the fridge vent and we put it down to something to do with the very hot weather we’ve been having and the fridge having to work overtime. Then we had a warning on the Alde panel “overheat, red fail” and no hot water. I took the fuse out, put it back and all was ok.
Then, this morning, we went to move the caravan ready for our trip back to the UK. The mover wouldn’t work at all. It tried but there was obviously not enough power. The voltmeter showed 10.3 volts. I checked the mains connector and all seemed correct and, in any case, it has a solar panel. We left the mains hook up lead in place and after an hour or so the voltmeter (mains disconnected for the reading) showed 13.1. As soon as I tried the mover, it dropped back to 10.3 volts. The battery is less than a year old.
Does anyone have any suggestions?
