Electrics
Jun 2, 2010
Hi, Can someone give us some advice, we recently went out in the van and noticed that the rear lights seem to be messing around...When you brake with the indicator on the fog light lights up and when the lights are on and you indicate both the lights and indictor flash dimly, have changed the plug and no difference, this problem only appears on the near side...is it major? - Help
Nov 5, 2006
805
this sound like an earthing fault. I would check the earth on the car from the black socket,& then check all the earth connections on the caravan This usually happens when water has gotten in to the road light fittings
