electrolux fridge
i have the above fridge fitted in my avondale dart but it no longer works off the 240v only gas.i hope it may just be a fuse problem.
does anybody know where the fuse would be,in order to change it?
thanks in advance
steven
Aug 2, 2006
221
Hi Steven, If the fridge is working properly on the other power sources and not on 230v then the element needs replacing,providing your getting power to the fridge, an easy job for a dealer, get them to service the gas side while they've got the fridge out!!
Steven, there could well be a 13amp socket in the underbed locker next to the fridge that has the fridge lead plugged in. Very simply the plug may have been dislodged, if not try the fuse. Presumably you have checked the other items running off the same breaker on your mains distribution panel.
