Seth your MOT tester is wrong, It has never ever been illegal to remove a cat from a diesel engined car, it has always been illegal to remove a cat from a petrol engined car, i dont know how the law applies to say hgv's, but that is undisputed fact and i am suprised at your MOT testers lack of DOT/MOT rules. as for the DPF...as yet the same applies to that,afterall my bravo does not have a dfp but they are fitted [optional] as they were to many cars.how caoud you fail one 57 plate car for not having a dpf because some do? they will no doubt make it compulsary one day but they cannot go back dating to 57plates or 58 59plates as the same applies there some have them some do not.
you keep going on about the emmision standard test, yes i am fully aware of how it is done, they weight the CO,so they can get the co per km rating as i have repeatedly stated and the CO gas has nothing what so ever to do with Soot particles, ala the DPF, so again the DPF does not cannot and will not effect your VED rating, which incedentally is the stupidest rating test ever.....The cat remark ie hitting with a hammer was a quip, joke, although it does work and is common practice at reputable Diesel centres, although i can imagine that some would refute it being a good idea
So to summerise on a diesel car there is no legal reguirement or MOT test failure for the removal of, as the only test done on a diesel for emmisions is smoke and as i have said before the smoke test is ancient for diesels,[please go look it up for yourself] and a modern diesel should not fail it with or without a cat indeed it shouldnt fail it with a blanked off EGR valve either as long as the engine is in good condition and i know that is a sticky piont with some too. And lastly to re iterate the DPF has nothing and plays no part in the VED rating system, but with it looking likely as some piont to be a compulsary part and the Diesel emmision test surely needing updating because its so ancient ie the amount of soot you can actually have, still. then at some piont i would expect this all to change. Note the rules are far strickter for HGVs.
I would not suggest anybody take off their cat or dpf or indeed blank off there EGR valve, as when working properly they do a fine job.becides more moden cars its not as easy as less modern ones IE pre 2004/5, more electronic control means more hassle for a start.but given the costs of replacement or fixing of some parts then i wouldnt hesitate on blanking my egr valve or as i have done before taking off my cat, but note my cars are generally bought with plus 70k on them so build up of soot oil ect leading to build up of blockages and therefore replacement parts is somewhat different to people who have new or low mileage cars and therfore hopefully do not need to do these things.
