Extension Mirror Problem
Aug 14, 2007
I've a bit of a problem with my extension mirrors.....
Whenever it is slightly windy (anything more than a bit of a breeze, not a howling gale!), if I drive at more than about 45 mph the mirrors fold back flat against the side of the car. I know they're designed to do this if I hit something with them - but not when I'm driving normally! The same thing happens sometimes when I encounter turbulence from a passing coach, truck etc.
I drive a Citroen C5. Anyone else have a similar experience, and found a solution? It can get a bit scary when you're passing a truck and you suddenly can't see anything as you go past them!
James
Feb 4, 2007
293
James you could try these. They are supposedly designed with soft mirror springs in mind. I use them and find they are very stable, give a good view behind and are very easy and quick to fit and remove.
Colin.
There used to be an accessory on sale that could easily be copied
It consisted of a sucker to stick on the car wing etc and a tape that was attached to the towing mirror and set with the car door closed so that it was just under tension
I rememeber seeing it at the NEC some years ago
