Fiamma Caravanstore
Mar 14, 2010
86
Further to my query regarding a Fiamma Caravanstore, has anyone come up with an idea as to how a Porch Awning etc. can be attached to the Caravan, when the Fiamma Caravanstore already uses the Awning rail.
This would then give me a choice- Fiamma or Porch
:dry:
Feb 3, 2008
3,790
Unfortunately any awning type device needs to use the awning channel in order to provide a waterproof seal. An extra device would require you fitting an additional channel to the van at a lower level, meaning you would have to penetrate the wall with screws and would miss any strengthening timbers in the wall.
40
It might be possible to use both a porch awning and a Fiamma depending on the length of the horizontal part of the awninf rail. A long caravan may have say 6m. And might take the shorter Fiamma to the rear and a small porch at the front.
You would need to measure carefully as both porch snd Fiamma are a bit longer than their stated widths when measured at awning rail. This is due to the lead in flaps and the bag respectively.
