Fitting a Status 530 Aerial
Dec 22, 2003
My Abbey caravan has a Status 315 omnidirectional aerial fitted as sttandard. I find it pretty poor so at the suggestion of Grade UK I'm think of replacing it with a Status 530 aerial.
Has anyone tried fitting one themeselves [preferbaly replacing the 315]?
Aug 8, 2005
181
hooray !
Someone else who thinks that the OmniDirectional aerial is rubbish - we found it absolutely useless too - mind I never thought the ealrier one was muuch cop either unless you were in an area with wonderful reception.
Sep 17, 2005
29
I thought it was me, tried the thing so many times. Checked the connections, the two different setting and nothing. Is it worth upgrading?
Aug 28, 2005
1,318
Go onto this web site http://www.aerialsandtv.com part of the article on caravan aerials says when you get a good picture in your van its because you are in a good reception area ,you would probabley get the same picture with a metal coat hangar ,
3,517
1,349
I change my 315 to a 350, in my case the long shaft one. I used the plastic dish Status sell to cover the holes for the original screws and cable. Fortunately I could locate the new hole on that disc but to get the internal bracket spaced the correct distance off the wardrobe it was a touch off centre. Only problem is finding the courage to bore a large hole in the new vans roof. I got a tube cutter for my electric drill from B&Q and bored through plastic & dish roof in one shot. I made a pilot hole with a piece of piano wire first from inside to make sure it was exactly the right distance from the wardrobe wall, the the big hole I drilled from the top.
All was easy and the reception performance is excellent.
