Would enjoy having water on tap in my caravan when on the move (plus loo which has an electric pump), but my present setup is an outside aquaroll plus a whale extereior submersible pump. Has anyone added a onboard water conversion. regards, Brian.
http://www.screwfix.com/prods/18266/Fixings/Cavity-Fixings/Hollow-Wall-Anchor-5-x-43mm-6-13mmBrian I made a frame with 2 U shaped 15mm copper pieces that the tank "sat" in .They were joined at the top with soldered T pieces so that there were 2 horizontal joining pieces the width of the tank that fitted up to the van floor
I should have called the fixings wall plates and these fitted on to the ends of the horizontals to give the attachment to the van floor
http://www.screwfix.com/prods/17416/Plumbing/Compression-Fittings/Wall-Plate-Elbow-Compression-Fittings-15mm
I could Email a pic if needed
Where are you?
The floor fixings were in to the outer skin and didn't affect the carpets
http://www.fwb.co.uk/mall/productpage.cfm/FWBGroup/434OSE/63639Hi Brian
the fittings are as on the link I posted as below and are available from B & Q as well as screwfix(The French love them)
They open out behind the panel and are very strong
I have towed with a full tank to Spain etc(naughty I know Roger)
When I had the mishap coming off a ferry it pulled the front olives off the end of the compression fittings but the fixings into the floor were reusable,(You can get a cheap setting tool which makes it easier when under the van)
I soldered the olives in place when it was repaired
I used a pipe bender to shape for the curved ends of the tank and solder elbows at the "sharp" end with a cross brace underneath
It would be worth getting the C A K tanks catalogue ane looking what they have
www.caktanks.co.uk
I was asking where you were because you could have had the frame I no longer need if you were local
Hope that helps
OK BrianHi JohnG, thanks for the offer of the "tank frame" PLEASE NOTE I am willing to pay delivery charge and as it is an odd item to post you could cut it into four(or six)parts and being copper I would use 15mm solder straight couplings to reassemble frame (payment by Paypal or cheque)being the middle of winter delivery is not a priority, if interested just let me know what would be posted - tank frame plus four wall plate elbows? Your fixings are what I hoped they would be as I used these on an earlier project a few years ago.
Q007708 Aquaflow Tanks (Q007708) 23 x 46 x 48 45Brian if you could arrange courier collection I could send you the frame and tank with float valve and inspection hatch F O C and you could ebay what you have to cover the cost
The dimensions are not much more than the tank which is 10 gallons
We are in Stoke on Trent postal area
I have asked PC forum website if there is a way of sending you my Email address so that we can sort it out between us
For float valve read low level warning light sender!Brian if you could arrange courier collection I could send you the frame and tank with float valve and inspection hatch F O C and you could ebay what you have to cover the cost
JohnG, you are a real gem for your very kind offer IF I can contact you direct by email will take up your invitation, delivery (I think) would not be a problem and for anyone reading this who wishes to deliver any item up to 30kgs between Ireland and Mainland UK. use -send it now.com- which is Parcel Force (same service either 24hrs or 48hrs delivery)for a standard charge of
