flat battery
Jul 3, 2008
155
my leisure battery is complely flat god knows, will it recharge or is it a new one required
Trev
Jul 21, 2009
101
Put it on a slow charge so that you don't boil the battery fluid,make sure it is topped up ,but not overfill,if after charging it looses it's charge off load then a new one is the only answer.
Jul 3, 2008
155
David, thanks for your prompt reply. the charger i have wont even attempt to charge it as it has a safety feture to stop charging if under 7 amps !! im just wondering if its goosed and we go away in the morning.
Jul 15, 2008
3,905
1,092
It is worthwhile noting that a lead acid battery can freeze in sub zero temperatures if it not kept in a state of charge.
The electrolyte can turn to a solid and crack the battery casing as it expands.
This will destroy the battery and also release the acid when it thaws.
