dallond said:
Hi! gagakev.The link is to me in another forum.Thanks for trying.
UMMMM am I going potty or is it this forum???? (sometimes does weird things!!)
The link is to a thread which was started on this forum in March 2010
Ive just clicked on it and it took me there, try again dallond
There's only three replies so going to havea go at copying;MEC Caravan Alarm
Last post]
Mon, Mar 15 2010, 10:21PM
Alan_374554099
Offline
Hi anyone help.I have a Fleetwood caravan with a MEC alarm
fitted, I am just getting it ready for the new season, had battery off
to re-charge. Found that battery past its best so got new battery. Gone
to fit it and when connected the alarm goes off, so put code in (as
stated in instructions book), but can't stop alarm.On the control
pannel there is 2 lights, 1 green and 1 red, when I connect battery the
green light is on. According to the instructions you press * button to
activate the control pannel and the red light should be lit to indicate
the key pad is active and the green light lit to show the alarm is set (
at this point only the green light is lit), then you enter your 4 digit
code, followed by 2 to disarm the system. Then the two lights should go
out, but nothing happens ie alarm still going off. Tried several
times.Can anyone help.Does anyone know if the company MEC Ltd at
Mytholmroyd, West Yorshire is still in business because can't contact
then on phone number on back of manual.Many Thanks
Sun, May 2 2010, 8:05PM
#1
matt_374566596
Offline
hi there i have the same alarm fitted to my caravan but the
alarm code wasnt passed on so i have no idea how to reset back to
factory settings ie the *1111 oringal code i have a contact number for
them but all it does is ring and ring i have seareched for the number on
line and all i can found with the same phone number is a pond liner
supplieron my system the sounder has been disconnected if you can found
the control box pull out the sounder cables red and black i have
searched online but cant found any help at allif you want the mec's
number reply and ill email it to you
Sun, May 2 2010, 8:31PM
#2
Clive-Cardiff
Offline
Have you tried disconnecting the battery then reconnecting. This has worked for me in the past
Fleetwood Heritage 640ES(T)
Seems to have worked, good luck
