Icaru5 said:My van has the same feature. I believe it’s a back emf from the pump motor as it stops rotating. Not remotely concerned, but if I was I’d introduce a diode in series with the pump on the negative side.
Why on the negative side? that will have the effect of raising the potential of the pump negative by a diode drop, and will do nothing to stop the back emf from the motor affecting the +ve supply.
It would make more sense to put a diode in the +ve supply to the pump.
But what would make even more sense would be for the control circuits to be properly designed to stop the issue in the first place.
