- Jan 21, 2008
- 86
- 0
- 0
The existing carpet in my relatively old caravan is somewhat dirty and would benifit replacement.
Due to the intended use the van will be put to, and that I have a habit of getting things dirty, I am not too keen on replacing like for like as knowing me a couple of weeks use would get it looking the same!
The van will mainly be used as accomodation at steam fairs, so there is plenty of potential for treading in mud etc or worse!
My thoughts are along the lines of
a) laminate flooring
b) linoleum
c) Some kind of Flotex type carpet.
As the van is not worth a lot and I am on a budget, cost is probably going to be the main factor, so b) is most likely. However I could be swayed by argument to any of the others or indeed any other alternative if a good case can be put!
b) linoleum
