floor noise
Aug 25, 2006
75
can anyone tell me if we have a really big problem with our floor,to start with we bought our eldiss 524l new a year ago and we have had nothing but problems (see below )
1 ,new battery box cover
2 ,all hinges and doors redone in some way
3 ,end bath room wall cracked
4 ,flooded bathroom floor due to not enough sealent on toilet door letting in rain water
5 ,new fault found( door window is not glued on all the way round causing wind and rain to blow though gap)
6 , faulty bracker
7 , missing deflectors under floor vents letting spray from road come into caravan
8, damaged table when new
and the very new one we have had while being away on holiday is
the floor severly creeks which it never did before now
May 4, 2005
2,622
Try checking the nearest cupboard to make sure the fixing screws into the floor are tight. I had this on mine and , after the initial panic,found that it was actually the cupboard creeking. Once tightened the noise stopped.
Brian.
Aug 25, 2006
75
Brian.
yeah checked that and all ok ,it worrys me because we found as days went on it got louder and spread further down the van,but we also found when we moved to another site the noise got better and not as spread across
May 4, 2005
2,622
Don't know what to suggest Neil, obviously moving the van changed something so maybe chassis slightly twisting when using the corner steadys to level van.
Brian (",)
