Found a kink in water pipe..
Dustydog said:
ProfJohnL said:
I'm not sure what Chisn7's concern is. It's likely to be better than it used to be with the kink!
The only minor point I can see is that with loop, the water may airlock when trying to drain down, but just a blow through should be fine.
Hi Prof.
I believe he is referring to the Whale water pressure sensor to which the pipe attaches.Not the pipe itself.
These sensors can fail and when it does the OP will.know where to look :cheer:
Hello Dusty,
Yes I understand he was referring to the pressure switch, but of all the water components in caravans the pressure switch are one of the more reliable components. Yes they may needs adjusting from time to time, but that's not a failure as such. And with the unrestricted flow of teh new pipe its likely to be better than before!
