French/Spanish screw-on gas bottle or adaptors
Kai
Mar 21, 2024
32
Hi, I just found these countries use clip-on regulator with bottle, but my caravan uses 30 mB regulator. I can not use two regulators together. Can I get adaptors or screw-on bottle there to use in my caravan? or any solution?
3,948
1,691
In essence yes, but to get you specific advise which continental bottle have you got in mind using?
My 27mm Gaslight adaptor directly fitted one of the French LeCube bottles, that was back in 2017.
The adaptor that married to the pig tail is like this LINK, important with the LeCube was the elevated take off featured here.
Your initial bottle contract comes [ or came] with a regulator, that you don't require.
Kai
Mar 21, 2024
32
Thanks! Can I get such an adaptor or valve there?
3,948
1,691
On that I can't help you, but Google might. I had mine for our Gaslight bottles here in the UK, and had known that with the higher outlet it was LeCube compatible.
Kai
Mar 21, 2024
32
Can I use butane instead of propane on caravan?
3,948
1,691
Absolutely and it is "better" in holding more "energy" and typically cheaper, but with a very important proviso.
It does not boil off anywhere as readily as propane, the real life ramifications of that being its use below 6C begins to be "difficult", and below 0C, totally impractical. So as long as your going in summer and not to cold high altitude locations is viable.
I quite frequently have used butane in the summer, its cheaper.
Reactions: Kai
