fridge fan
Has anyone fitted a small vent fan to the fridge outlet, and if so, does it really enhance cooling performance? ----do I fit one fan or two??---the fridge I have is a Thetford N90
Hi, call in at your local computer shop and purchase a couple of pc cooling fans (5 or 7" I think) and then you will need a reich thermo-cooler part number 233-1068 at
Nov 4, 2004
1,191
Hi i use a 4" square 1" deep 240v electric fan cable tied to the fridge vent,then pluged into the outside socket.Ok only good on mains , but does keep the fridge very cool.
Jan 17, 2007
17
Hi
We fitted a single 8 cm computer fan to the outlet for our 12v compressor fridge which kept cutting out due to the heat. This was in France and Spain with temps at 30C most of the time. Worked perfectly.
We then fitted an additional absorbtion type fridge, 12v, 240v and gas, and again fitted a fan. The fridge got a lot colder due to the heated being extracted away and we managed ice cubes from it whilst parked in temps of 30C
Just an ordinary cooling fan for a PC..even buy them off e-bay for a couple of quid.
Cheers
Sep 30, 2006
208
I've done a similar thing except that I wired the 2 fans in series, slower but almost silent. One pulling air in (at the bottom) and the top one extracting...worth doing thanks to global warming!
Nov 4, 2004
1,191
Hi Mickey
Do you have the maker's name and part number of the 240v fan?
Mac
Hi Mac
Not too sure of the manufacturer,but if you go to rswww.com the part number is 101-8024.This comes with flying leads so you have to crimp the 2 core mains leads to it.This can be a bit noisy in the van at nightime but i only use to run it in the day/evening
