- Jun 16, 2020
- 5,521
- 2,472
- 17,935
In my last Lunar caravan I fitted a fridge fan made from bit I bought from China. It worked beautifully, it could just be heard turning on and off during daytime hot weather. And the fridge was noticeably cooler in 36 degree temperatures.
I have just purchased a new fan kit for our new van. But after using the van for a few days in quite hot weather and being very impressed with the fridge and freezer operation. I may not fit it.
But, if I do, I may first make a modification to the kit. And I am looking for some advise.
I have tested the kit with a USB power supply and it works well. But I had to first decipher the controls. If anyone wants to purchase they are available on eBay, Amazon and AliExpress. I paid £13.
Instructions:
I would re-wire these in series, which might put around 7 volts in use. (I think the will just run a bit faster, if they blow, so be it. 12 volt fans are cheap enough).
Any comment on my logic.
Instructions:
- Power up
- Press left button once
- Scroll through until screen shows ‘P0’
- Press left button to select
- Use arrows to set the temp the fans should turn on, (say 32, needs trial and error)
- Repeat, but setting with P2 and set the lower temp at which the fans will turn off.
