Hi
I've recently bought a second hand van - 6 years old... generally very impressed with it. First three times out I've had enormous problems lighting the fridge. It's an automatic ignition so you turn on the main dial to gas, and it starts the ignitor (shown by the flashing light and the ticking noise)and you then hold in the Min/Max knob till it lights and hold in for 10-15 seconds before releasing.
Problem is.....when released it obviously goes out as the auto ignite comes on again. I've sat there on three occasions now holding the knob in for varying times between 10 seconds and 3 minutes but still the same.....goes out when released.
If you then leave it for half an hour and try again.......it works !!!!!!.
At first i thought it might be damp and as you sit like a lemon holding the knob in to keep the gas lit, it dried it out making it easy to light later. However, before I left the last camp I turned it off then tried to light it again immediately, (having been on for 2 days it obviously wouldn't be damp)....but the same thing happened.....still wouldn't light.
Thought it might be the thermo-couple device but then that should still have been hot enough having just turned it off, to light again straight away.
Any ideas or similar experience would be so helpful as i still have a sore thumb from holding the damn button in for so long.........Thank you
