Hi All,
When 12s connected, car engine running and the fridge switched to 12v a relay switches in the distribution box under the sofa.
It doesn't switch a lot. Just sometimes. But it sounds like its mostly off. About once every 10 seconds there is an upbeat 'click-click' (presumably an on click) and then almost immediately a downbeat 'click' (presumably an off click).
I know its to do with the fridge cos when I turn the fridge to off it stops.
Should it do this ? I thought the fridge relay for 12v operation was in the car and after that the wires ran straight to the fridge.
I have put on a new 12s socket and plug. I have double checked their wiring. I have run the car at 3k rpm with a brick on the pedal. I have disconnected the van battery to make sure that the fridge is the only thing drawing current from the car. I have checked that the voltage across pin 6 (red) and 7 (black) is 14.2v so the cars alternator seems fine. The car has a relatively new battery and is at 12.8v (fully charged). The alternator can supply plenty of current to run AC and DVD players when it wants to....
So I think that foir some reason the fridge is not comming on when on 12v... or am I wrong and the relay switching is for something else or normal ?
C
C
